wood floor staircase transition at wall?
user-402418 | Posted in Construction Techniques on August 2, 2003 02:58am
I plan on installing a hardwood floor on the 2nd story of my house.  I would like to continue the hardwood floor on the stairs as well.  Currently the stairs are carpeted and the staircase walls are drywall with a textured finish, as is common here in the Southwest.  What is the best way to install the wood floor on the stairs to obtain a clean transition on the ends at the textured wall?  Is it possible to cut the risers and treads to length and just apply a small bead of caulk at the wall?  Is there any other way to trim it?  I know I’ve seen staircases with a base molding applied at the wall transition to cover the board ends, but these are usually applied on a flat, un-textured wall.
Thanks,
Charles
