I think i know the answer to this, but i need alittle confirmation and support.
In which direction should strip wood flooring be laid in a rectangular space?
The code requires installing an approved material to slow the spread of fire between floors and adjacent vertical and horizontal cavities — here are the allowed materials and required locations.
I usually run the flooring with the length of the room, however, I always try to run perpendicular to a 1"x6" subfloor if that applies.
There are valid reasons for running either way.
First generaal rule is to run it with the incoming light from outside.
Then there are plenty of reasons for breaking that rule.
