I would appreciate any advice on installing wood flooring in the basement of a home.
The owner wants the basement finished for a family
room. We thought the glue down laminate variety
might work best to eliminate a height problem
with the other rooms.The basement has been there for 30 years and shows no signs of water.
John Keller
This centuries-old paint offers vapor-permeabiity, maintainability, and longevity with zero VOCs, but know its limitations before you get to work.
John, walk-out or regular basement? How dry is dry? I'd be
inclined to seal the concrete with asphaltic sealant, cover that with 10mil poly, top with 3/4 plywood and install regular 1/2 inch or 3/4 inch hardwood. Staple the 1/2" and floornail with a special adaptor plate the 3/4".
But that's just me.
George,
The basement is accessed by a stairway and has no
walkout steps. I can see no evidence of moisture or
water stains on any of the existing walls. How would
3/4" plywood be fastened to the concrete. Would a
Remmington stud gun be adequate?
*John: I dunno. I spent many years in S. Florida, practicing architecture, and I've seen many different attempts at wood floors on conc. (slab on grade, very high water table...should be a similar situation, don't you think?) Best solution seemed to be sleepers on the slab, with an air space. Direct layment never worked there. The idea of asphaltic sealant simply invites a pressure head to build up before it lets go. I would suggest floating the flooring, a la Pergo. In fact...That would also help you with your headroom problem...laminate flooring on a foam mat. Allows the slab to breathe; the whole thing can move as a unit, so expansion isn't a problem.Good luck!
*John,Most or all of the hardwood floors I have installed say not to install below grade,so if i were u I would pick out the floor u want to go with and find out what the floor company has to say.It is there garentee and they would know best.good luck ted
*I agree with the how dry is dry. Concrete floors can be very sneaky. That concrete can be letting all sort of moisture out, but look dry as a bone. Certainly enough moisture to make your new hardwood floor look like poop. I would seal, and go with the 10mil poly as per georges sugestion, then sleepers, and 3/4 plywood. If there is a space requirements, I would look to a non-wood wood floor (Pergo) or something completly different.I've found it far better to advise a customer against something that won't hold up well, rather than doing what they want, just to make them happy in the short term. People will see a bad floor with your name attached to it....they most likly will not hear that you advised them against it.
John Keller
