Wood floors on conc. slab
Ginbobpat | Posted in Construction Techniques on August 19, 2010 06:37am
I’ve been asked to look into istalling a wood floor on an existing garage slab on grade.  I know how to test forr moisture by taping down a piece of plastic.  I have no idea what the conditions are under the slab or at the edges.
I am located in central N.C. so freezing is not a big issue.
Any help would be greatly appreciated.
Thanks, Dan
  1. triptophoniacle | Aug 20, 2010 11:02pm | #1
    Is the garage being converted to living space?  I would  do an engineered wood with a trowelled on adhesion.  Otherwise vapor barrier and fur up with sleepers and plywood. Hope the garage roll up door doesn't get left open...
