wood siding stain recommendations
semipro | Posted in General Discussion on December 15, 2006 11:29am
The western red cedar siding on the outside of my house needs to be re-stained.  It was previously treated about 5 years ago with a Glidden stain.  Here are my preferences for the product:
  • Can be sprayed on
  • Water clean-up if possible
  • Low odor if possible
  • Long lasting
  • Sealing, water repelling
  • Semi-transparent if possible
  • Include fungicide to prevent mildew growth if possible
We live in the VA mountains if that’s a consideration.  The house is quite tall and there’s a lot of siding so I’d rather spray than brush.  I’ve had recommendations for a product for Sikkens but I understand it requires brushing on.  I’ve also heard of, and seen, a product called Cecol(sp) or something like that.  I’ve been unable to find out more about it because I apparently am not spelling it correctly.  The application I saw looked great though.
Thanks if advance to responders!
  1. migraine | Dec 16, 2006 12:30am | #1
    The product your are looking for is SIKKENS made by Cetol Marine.  I have friends that swear by the stuff, But I personally haven't used it
    http://www.nam.sikkens.com/product-category.cfm?product_category=exterior
    hope this helps
    Edited 12/15/2006 4:33 pm by migraine
  2. twofingers | Dec 16, 2006 01:54am | #2
    Sikkens is, IMHO the longest lasting, most beautiful semi transparent finish available. Just keep in mind that your wood will have a definite shine when you finish coating with Sikkens.
    Remember though - one of the key factors for finish longevity is color. Go with the darkest color you can stand.
    All finishes sprayed on wood should be "back-brushed." Spray it on and work it in with a cheap 4" brush.
    Sikkens is definitely NOT low odor though and it requires mineral spirit for clean-up.
    So far, I have not found a water clean-up product that will seriously last more than 2 - 3 years.
    The "cecol" you are referring to is possibly "Cetol?" Cetol is a Sikkens product.
    Sikkens is probably the most expensive finish you can buy. I think it's in the $360.00 per five range.
  3. Catspaw | Dec 16, 2006 05:25am | #3
    Also check out Penofin.  It's an oil based product, solvent cleanup and not low odor.
    I think that any product that you spray will need to be back brushed.
    http://www.Penofin.com
    Rich
Drafting the 2027 IRC
  • The New Old Colonial
