wood stove in basement
jimk1287 | Posted in Energy, Heating & Insulation on February 15, 2009 11:33am
i am considering installing a small wood stove in my basement more or less to enjoy a fire and relax, and whatever heat it gives off to help with the house is fine but mainyl for atmosphere. My question is how can i vent this….can i run the stove pipe out one of my basement windows and let it vent straight out or do i need to run it out the window and up past the roof ridge? any other tips i would appreciate
  1. BoJangles | Feb 15, 2009 11:50pm | #1
    The hillbillies around here prefer the first method.  Oh BTW, check with your Homeowners insurance agent first.
  2. Piffin | Feb 15, 2009 11:56pm | #2
    top of flue needs to be three feet above a ridge or two feet above any other part of the structure within ten feet of it.
    and you want to use insulated class A pipe or it is likely to be too cold and form creosote, thn chimney fire, then siding fire which leads to a house fire
    This is nothing to go about this casually.
  3. MHolladay | Feb 17, 2009 03:37pm | #3
    Jim,
    "Can I run the stovepipe out one of my basement windows and let it vent straight out? Or do I need to run it out the window and up past the roof ridge?"
    No and no.
    1. Modder | Feb 17, 2009 05:33pm | #4
      Yes, might want to stay away from things that might be likened to this photo.
Mortar for Old Masonry
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
