Wood Stove in manufactured home
opiegarden | Posted in Energy, Heating & Insulation on July 15, 2006 07:55am
I’m planing to put in a wood stove in a manufactured home. Have any of you done this? If so what do I need to do to keep it safe. What are some areas that are easy to mess up? Any help would be appreciated thanks
  1. brownbagg | Jul 15, 2006 08:33pm | #1
    about eight years ago, Sears had a wood stove that was certified for Mobile homes. Now around here alot of people do it with the cheapy stove, but I would be afraid to.
    Sphere | Jul 15, 2006 09:21pm | #2
    Make certain the chimney support box falls between the roof trusses . DO NOT cut and head off one of them. What I had many , many yrs ago was little more than a 1x2 top chord, and a 1x2 bottom chord, with 1/4'' plywood gussets about 3x3" stapled on either side every few feet...not a truss as much as a strut.
    Stay way clear of panelled walls. Make sure the hearth base is over the steel, and check the underpinning at the stove location and double up if needed.
    There is no cure for stupid. R. White.
  3. Ray | Jul 16, 2006 04:56pm | #3
    You'll also need an outside air inlet for the stove.  A fireproof duct through the wall or through the floor and to an outside wall.
    1. opiegarden | Jul 16, 2006 05:20pm | #4
      Thank you very much for the responses.
      Edited 7/16/2006 10:20 am by opiegarden
      1. Mooney | Jul 16, 2006 08:03pm | #5
        following good advice
        Pic a unit that is moble home specified as they will normally be zero clearnce .
        Venting should be triple stainless with aproved connections and arrestor cap.
        Only buy with detailed instructions from the manufactor .
        Tim
  4. Piffin | Jul 17, 2006 04:37am | #6
    The biggest diff from typical site built homes is that due to the way mobiles and modulars are built is that they are assumed to be more air-tight, so code requires they have air supply vent in addition to the flue out. If you fail to by a unit certified for manufactured home and install according to instructions, the home can easily fill with CO and kill the occupants.
Choosing a Paintbrush
  • The New Old Colonial
