Wood trim for a metal building
debutant10 | Posted in Construction Techniques on January 7, 2003 07:30am
Our barn is a metal building, the overhead door openings are “framed” in red iron. I would like to trim-out the red iron with pressure-treated cedar. Can I attach the cedar boards directly to the red iron with self-driiling screws? Do I need to put anything betweem the red iron and the cedar? Thanks.
Brenda
Edited 1/6/2003 11:51:55 PM ET by BCG
  1. andybuildz | Jan 07, 2003 07:33am | #1
    I never heard of pressure treated cedar but none the less I think for added saftey I'd put some 30lb felt behind each piece to keep the condensation off. If the screws protrude to the inside you may want to consider a piece of trim on the inside as well to accept the screw ends sandwhiching the metal between them
        HAve fun
                  Namaste
                             andy
    "Attachment is the strongest block to realization"
    1. debutant10 | Jan 07, 2003 07:55am | #2
      Thanks for saving me face and time looking for something that doesn't exist. I just assumed that any lumber in contact with concrete had to be pressure-treated and thus the cedar would be. Should I also caulk the edges to keep moisture out? Thanks again.
      Brenda
      Edited 1/7/2003 7:04:56 PM ET by BCG
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
