Wooden Slide materials?
apiersma | Posted in Construction Techniques on April 7, 2010 04:31am
I’m soon to embark a wooden playset for the kids. The plastic slides cost a small fortune, so I am toying with the idea of making a wooden slide.  I figure I could set 2 2x8s like stair stingers with some bracing perpendicular every foot or so. Then use MDO, PVC trim, or some other plastic/ wood compostie trim to make the slide surface. Thoughts?  What material is the slipperiest and can withstand the outdoors.?
  1. davidmeiland | Apr 07, 2010 07:08pm | #1
    What about sheet metal
    Go buy yourself a ~24" x 8' piece of galv sheet metal and laminate it to a piece of plywood. Screw on some 2x for the side rails. Those side rails definitely need to be splinter free, and I would wax the metal surface.
    How much is a slide if you just go buy one?
  2. DanH | Apr 07, 2010 07:31pm | #2
    Yeah, when I was a kid we had a slide my dad made.  Had wooden sides (no idea what material, but roughly 2x6 dimension) and a sheet-metal bottom.  Got rusty every winter but was quickly polished off come spring, since every kid in the neighborhood used it.
    Do, of course, be aware of safety -- use wood that won't easily splinter and give it a good coating of some sort (eg, several layers of oil paint or spar varnish).  Make sure the exposed edges of the metal are rolled.
  3. apiersma | Apr 07, 2010 09:03pm | #3
    I'm avoiding metal. It gets too hot in the summer around here.
    1. DanH | Apr 07, 2010 10:28pm | #4
      That's part of the charm.
  4. apiersma | Apr 08, 2010 09:38am | #5
    Agreed
    It was part of the charm, but kids were so much tougher back then. My kids are wimps.
    The orange box sells a plastic/wood trim boards called Tuff Boards.  I can get a 12 footer by 7 1/2.  If I pocket screw and glue two side by side, I 'd think that woud make a good slide surface. That have no structural value so they have to be on top of ext plywood or something.  Then a couple coats of sparthane to ensure slickness.
    1. DanH | Apr 08, 2010 08:40pm | #6
      Except that that seam is a major potential problem area.  If it has any potential at all to catch clothing it will.
