Working with old aluminum siding
toolined | Posted in Construction Techniques on July 7, 2015 09:43am
The siding on my house has to be fifty years old. I want to expand a mud room back entrance by a foot wider ,can I cut the siding in place and tuck a “j” channel in the cut to flash it. I really don’t won’t to remove it if I don’t have to
  1. florida | Jul 08, 2015 10:31am | #1
    Sure, use a sharp utility and/or an oscillating tool witha fine blade. I'd probably tack  a 1X4" up as a straight edge as well.
  2. DanH | Jul 08, 2015 02:19pm | #2
    I'd try good avaition snips, perhaps the "nibbler" variety, and also try a Multimaster or knockoff with a fine metal blade or an abrasive one.  Likely you'll want to use a combination of tools.
    A lot depends on how heavy the AL is and how tightly fastened, plus how awkward a position you manage to be in.  (Seems like there's always a bad  corner to deal with.)  The potential problem with the Multimaster is that it will shake the loose AL so badly as to wrinkle/tear it (and make a terrible racket), while the snips simply may not be able to get close enough to cut what needs cutting, especially where the sections join.
  3. calvin | Jul 09, 2015 07:52am | #3
    I have done this..
    Plywood blade put on a circular saw backwards.
    a shoot board to run the saw on is ideal, but a pc of laminate taped to the sole of the saw works as well when free handing.  This keeps you from easily marring the finish on the siding.
Grout-Free Shower Panels
  • A Postwar Comeback
  • Natural Simplicity
