wrapping rough openings
| Posted in General Discussion on July 5, 2005 03:53am
Why does the top of a rough opening (bottom of header) need to be wraped in plastic?
The bottom and sides make sense to me (although I have switched to using Jambsills for the bottom and self-adhesive stick on flashings for the sides), but doesnt wrapping the bottom of the header create a “bucket” instead of an “umbrella?”
Best answer I’ve gotten from anyone so far is – “don’t know, that’s the way we always did it.”
  1. davidmeiland | Jul 05, 2005 05:13pm | #1
    It doesn't, according to the flashing article in the latest issue of JLC. The detail there is to tuck the flange under the housewrap at the head, and also to use a piece of Vycor or similar adhered to the sheathing above the opening and extended down over the flange. It's worth reading that article and/or seeing his demos at the JLC show. A good detail in most respects IMO.
  2. blue_eyed_devil | Jul 06, 2005 02:04am | #2
    It doesn't make sense housedktr, just like a lot of stuff the window gurus will tell you.
    This makes sense to me: if you are letting water get behind your siding, you are doing something wrong....fix the siding!
    blue
    1. housedktr | Jul 06, 2005 03:16am | #4
      I've learned not to assume the siding is keeping all the water out, no matter who put it up or what kind it is.
    dieselpig | Jul 06, 2005 03:08am | #3
    It isn't that the housewrap is supposed to wrap up under the header... it's just supposed to extend down over the nailing flange or the Z flashing at the head of the window.  If you wrap the housewrap down under the bottom of the header (and I do just that),  you're supposed to slice it and slide either the flange of the window or the Z-flashing up into the slice, so the housewrap ends up overlapping the window flashing.
