Wrapping steel posts
| Posted in General Discussion on October 21, 2000 05:31am
I have a freestanding pergola/porch that has 6 4″ sq steel posts. I want to wrap the posts with 2x wood to give the posts a more solid look (looks like a skinny spider right now – I’ll wait till after Halloween before I start 😉 and chamfer the corners for a little interest.
What is the best way to secure the wood to the steel posts?
  1. Mike_Smith | Oct 17, 2000 06:13pm | #1
    shoot some 3/4 ply blocks into the lallys with ramsets... watch for richochet... then box the posts.....
    1. calvin_ | Oct 17, 2000 09:53pm | #2
      *That metal should be soft enough to drill and/or use tapper screws. Counter sink and plug.
      1. jim_at_great_white | Oct 19, 2000 01:31am | #3
        *you should just be able to wrap them without any mechanical attachment. Just build a box that fits tight around the posts. Put three sides ttogether first then add the fourth after the other three are around like a letter U . If you really want to attach this other than friction add some construction adhesive to the inside of the wood assembly before you put it around the steel.jim
        1. Jeff_J._Buck | Oct 19, 2000 06:14am | #4
          *Ask a simple question, get three good answers! Pick one which best suits you and available tools. Jeff
          1. Tim_Kline | Oct 20, 2000 03:37am | #5
            *b WBA At Your Servicejust glue it dammit !oh, that one's already taken...
          2. S_Edwards | Oct 21, 2000 05:31pm | #6
            *Greg: You may be in for a special treat each spring. Woodpeckers found my posts attractive. That hollow ring is perfect in the spring for marking one's territory and finding a mate, usually just before 5 A.M. Funny thing is I got to like it. I saved one of the posts and will reinstall it in my back yard next year.
  2. Greg_Finnegan | Oct 21, 2000 05:31pm | #7
    I have a freestanding pergola/porch that has 6 4" sq steel posts. I want to wrap the posts with 2x wood to give the posts a more solid look (looks like a skinny spider right now - I'll wait till after Halloween before I start ;-) and chamfer the corners for a little interest.
