Your advice on buying Hearing Protection – what’s best practice, best tools here?
TinyHouseCult | Posted in Tools for Home Building on July 29, 2018 08:35am
Hello!
So I’m preparing to purchase a nail gun, the Paslode IM360Ci.
What’s the best way to protect your hearing? Any advice is appreciated!
Here are the stats: the nail gun has a dB(A) rating of 109 and I’d guess a more relevant stat of 138 dB(A) for the sound pressure level.
Probably not as high as a real gun but then it’s being fired all day long so…
I was currently running with getting some gunshot ear plugs and then covering them up with the 3M Peltor III, but is there something I should be aware of?
  1. florida | Jul 29, 2018 02:58pm | #1
    This is what I've used for 25 years. The best hearing protection is what you have when you need it. A pair of big muffsain your truck do you no good. I put these around my neck when I get dressed every morning, 7 days a week so I always have good hearing protection. The impact sounds from a nail gun are the worse thing you can do to your hearing so please were something.  I usually lose these before I wear them out.
    https://www.homedepot.com/p/3M-Reusable-Corded-Earplugs-3-Pack-90716-3-10DC/202195388
    1. TinyHouseCult | Jul 30, 2018 06:47pm | #3
      Convenience is a good point, I'm adding some corded earplugs to the shopping cart.
      I have a Peltor Optime III earmuff which is 35 dB, when combined with 39 dB corded earplugs that should give me 40-44 dB of protection according to The Internet.
      I don't know about the impulse effect from a nail gun - but this should protect me from Jill Drake
      https://en.wikipedia.org/wiki/Screaming
      "The loudest verified scream emitted by a human measured 129 dBA, a record set by teaching assistant Jill Drake in 2000"
  2. oldhand | Jul 30, 2018 11:51am | #2
    just do it.....
    Best is the one you will consistently use. That probably depends on your personality.
    My wildman personality has helped me lose much of my hearing.
