Zero Clearance Wood Fireplace
NateMeredith | Posted in Energy, Heating & Insulation on March 24, 2002 12:55pm
One of my customers subscribes to TOH, which I can’t figure, I give her my FHB to read.  Oh well…  Anyway, I saw an article about zero clearance woodburning fireplaces that look to be using B vent.  Does anyone know anything or have any experience?  I don’t remember the name of the company, and recycling day has passed so the mag is gone.  Just curious, I never heard of such an animal.
Nate
  1. TooManyTools | Mar 24, 2002 10:10pm | #1
    Inserts that are rated as a gas fired appliance may use Type B. vent.  In some jurisdictions you can use Type B vent with a masonry fireplace if you post a PERMANENT notice that the fireplace cannot be used with solid fuels (wood or coal, etc.)  I just did a vent design for a two sided fireplace in a hotel here in Denver with B vent.  You have to be careful about sizing.  I recently was an expert witness in a case where the fireplace contractor went to a local B-vent distributer and gave him the rating of the logs to size the vent.  It was sized as if for a furnace or boiler, 8" instead of 18" for a fireplace.  You have to size for the dilution air and a face velocity of 48 fpm (ASHRAE Handbook of Fundamentals 1997).  I'm collecting quite a few horror stories.  Hey Andy need an article??
    1. NateMeredith | Mar 24, 2002 10:28pm | #2
      I recall that the article (it was really more of a small product description) referred to a double wall vent, and I am the one who labeled it b-vent. This was a manufactured fireplace that burt real wood, and the vent came out the top and went up through a chase through the roof. Do you have any insight on this appliance? Though I don't remember the name of the manufacturer, I do recall that there was only one company making this type of unit. Thanks for the feedback.
      Nathan
      1. TooManyTools | Mar 24, 2002 10:58pm | #3
        Double wall vent could refer to B-Vent but if it was for a wood burning fireplace it would be High temperature manufactured chimney sometimes called Class A.  B-vent has a maximum temperature rating of 450 F.  High temperature vent has variuos ratings but the minimum is 1100 F continuous and up to 1400 F for one hour I think.
