Zone Perfect two zone controller problems
M2adrJBVux | Posted in Energy, Heating & Insulation on June 26, 2010 01:22am
I have a two zone controller made by Zone Perfect. It is two years old and broke. Warrenty is a whopping 1 year. I live above Sacramento and this unit is only used during the summer months. I usually set the thermo. to 79-80 degrees.  This unit has not seen a lot of action!  $550-600 to R/R.  Has anyone else had problems with this company and their products? Was this just a fluke or is this brand a piece of crap? Suggestions for other reliable zone controllers for HVAC?
  1. DanH | Jun 26, 2010 02:38pm | #1
    I suspect that your basic zone controllers are all pretty much similar (a small computer chip, a bit of logic, and some relays), and run about the same price with the same features and the same failure modes -- it's not rocket science.
    If you have, say, a 3-zone controller but are only using 2 zones it may be that you can just switch a failing zone to the unused terminals or some such -- depends on what precisely has failed.
    We have an EWC unit that's 4-5 years old.  Can't say that it's good or bad -- it's worked so far.
    MarkH | Jun 27, 2010 08:21am | #2
    Something like that can be repaired generally by someone who knows electronics.  A relay may be stuck, or a transistor failed etc.  I work on that sort of stuff very frequently at work.
    I would contact the company first and see if they offer a exchange service.
  • Tall Deck on a Sloped Lot
  • Making and Installing Wood Wall Paneling
