Adding a window to a balloon framed wall
1110d | Posted in Construction Techniques on April 15, 2010 11:53am
I have a non bearing gable wall that I want to add a window to.  The wall construction is balloon framed and the new window will be on the second floor.  Typically I’d put shoulder stud in between the header and the bottom plate.  However, with balloon framing, there is no bottom plate.  How do I support the header (2-2×4’s) in a manner the inspector will approve of?
  1. calvin | Apr 16, 2010 07:00am | #1
    Simpson HH4
    Check out Simpson @ http://www.strongtie.com
    These hangers are sure to satisfy the inspector.
    1. 1110d | Apr 16, 2010 09:09am | #2
      I thought about them, but they won't work.  A double header means the flanges of the hanger will be off the stud.  I would need a special hanger with the flanges turned inwards.  They exist, but it's a special order item with a long lead time.
      1. calvin | Apr 16, 2010 11:15am | #3
        Are you sure these won't work, they fasten to the king stud (in your case-the closest pair of studs in the wall)  You need to oversize the header for the length (not that it makes a whole lot of diff. in that gable end)
        Sorry, the pictures show up on my reply b/4 posting but don't when it comes up on the board.  I'll try something else.
        HH Header Hangers
        View Image  Print this page
        View Image  Email this page to a friend
        Load Table <!-- UNCOMMENT IF SECOND TABLE
        TABLE NAME
        SECOND TABLE -->
        Gallery of images
        Code Reports
        Drawings
        Catalog Page <!--Anchoring Solutions -->
        Related Categories <!--Technical Bulletins -->
        Help for downloads
        For fast, accurate installation of door and window headers and other cross members. HH header hangers can speed up the job, strengthen the frame, and eliminate the need for trimmers.
        Material: 16 gauge
        Finish: Galvanized
        Installation:
        Use all specified fasteners. See General Notes. <!-- UNCOMMENT IF NEED SPECIAL NOTE GREY BOX
        Special notes
        /UNCOMMENT -->
        Attachment to 2x studs will result in two round holes not being filled in the studs and load reductions as noted in table.
        View Imagetop Gallery:
        roll over images below to see larger image
        HH4
        HH Load Directions
        Typical HH Installation
        <!-- UNCOMMENT IF MORE THAN 4 IMAGES FOR GALLERY
        CAPTION5
        CAPTION6
        CAPTION7
        CAPTION8
        /UNCOMMENT IF MORE THAN 4 IMAGES FOR GALLERY --><!-- UNCOMMENT IF MORE THAN 8 IMAGES FOR GALLERY
        CAPTION9
        CAPTION10
        CAPTION11
        CAPTION12
        /UNCOMMENT IF MORE THAN 8 IMAGES FOR GALLERY --><!-- UNCOMMENT IF MORE THAN 12 IMAGES FOR GALLERY
        CAPTION13
        CAPTION14
        CAPTION15
        CAPTION16
        /UNCOMMENT IF MORE THAN 12 IMAGES FOR GALLERY-->
        View Imagetop Load Table: See code report listings below
        Loads have been increased with no further increase allowed; reduce where other loads govern.
        For 3x posts, 16dx2 1/2" nails may be substituted with no reduction in load.
        For SPF/HF lumber use 0.86 x DF/SP allowable loads.
        NAILS: 10dx1 1/2= 0.148" dia. x 1¹⁄₂" long, 16dx2 1/2= 0.162" dia. x 2 1/2" long, 16d = 0.162" dia. x 3 1/2" long. See other nail sizes and information.
        View Imagenext  View Imagetop Code Reports (PDFs):
        Legacy Reports
        IAPMO ES ER
        ICC-ES ESR
        CITY OF LOS ANGELES
        STATE OF FLORIDA
        ICC-ES NER
        ICC-ES ER
        ICC-ES ES
        HH
        See specific model numbers for code listings.
        HH4
        ESR-2606 / ESR-2523 *
        RR25716
        FL10446
        HH6
        RR25716
        FL10446
        * ESR-2523 is an Index of many of Simpson Strong-Tie Stamped and Welded Cold-formed Steel Products for Wood or Cold-formed Steel Construction
        1. 1110d | Apr 16, 2010 10:16pm | #6
          The hanger is a bit different than the one that I was thinking of, but it still won't work.  Balloon framing has lumber which is true to size.  In other words, the hanger is 1/2" too small.
          The correct hanger would be a concealed flange hanger, but they don't offer one for 2x4's.  Guess I could step up to 2-2x6's, but the hanger will still be a special order.
          1. calvin | Apr 17, 2010 09:46am | #8
            1110d
            Here's my take for what's it worth.  Having worked on many homes of your type construction, I've seen many full bearing walls constructed w/no headers over openings.  Your inspector should be the first one to ask about this application.
            Your lumber is oversized for the hangers, the hangers are not undersized really.  Plow out one side of your king studs to fit the hanger.  Insta your conventional lumber header.  Build out the face of it to flush your framing.
            Do you have access to both sides of your wall?
            In a pinch-ask the inspector if 1/4'' steel angle bolted to the king stud would appease him if the hanger won't work for you.
            Honestly, you have a situaton ( if not super wide of an opening ) that probably wouldn't be a bad deal w/o a header.
          2. 1110d | Apr 17, 2010 10:18am | #9
            Based on past conversations with the inspector, I know that he likes hangers.  Actually, I believe his affection for them is beyond "likes".  It might be bordering on fetish.  Unfortinately, I don't have access to both sides of the wall.  Based on comments by the inspector, if I wanted to use a steel angle, he would want some engineering on the bolts.  He had also told me previously that my old growth fir studs are "ungraded" and that per the code would be classified as a grade #3 stud.  In other words, in his eyes, because these studs were not graded they have no structural value.  Basically, he's the stereotypical CYA, apply no common sense building inspector.
          3. calvin | Apr 17, 2010 11:18am | #10
            jee-zus
            Wants 'bolt specs"?  A pity you  can't open up the wall somewhere else and ask him how in the hell it's still standing.  Some of the older framing is remarkable in it's ability to stand straight and true over a hundred yrs.  And this with minimal engineering.
            Could you use the angle, and get enough info out or the Strongtie site for shear/pullout on some of their fasteners?  Surely he could extrapolate the hangers ga. and fastener schedule for a beam that's holding a whole heck of a lot more than a window opening in a gable end.
            You aren't vaulting the ceiling in that wall and installing a ridge beam are you?
          4. 1110d | Apr 17, 2010 11:59pm | #11
            Nope, it's just a simple 24"
            Nope, it's just a simple 24" square window into a non bearing exterior wall.  Seems so simple!
      2. DanH | Apr 16, 2010 06:47pm | #4
        Install a "joist" below the
        Install a "joist" below the stud, jack studs bearing on the "joist", then the header bearing on the jack studs.  Or just bolt the jack studs to the existing studs.
        1. 1110d | Apr 16, 2010 10:02pm | #5
          Sorry, but I'm not following you.  The joists are parallel to the wall, so I can't see a way to install a joist below the window.
          1. DanH | Apr 16, 2010 10:23pm | #7
            Attack a couple of (single) joist hangers and drop a piece of lumber into them.
  2. Clewless1 | Apr 18, 2010 01:39am | #12
    I recently built a new house. All my 'headers' for windows in non bearing gable end walls were flat 2x6. No load = no header required. Before you assume I had lax inspectors/BO, quite the contrary; I discussed it with them and they had no issues.
    You shouldn't need a header in your situation. Maybe for really large windows, but not 'normal' ones.
  • Townhouse Transformation
  • Mortar for Old Masonry
